oil filter
Old Aug 29, 2008 | 03:18 AM
xplorerboy's Avatar
xplorerboy
oil filter
i want to change the engine oil and oil filter on my 01 ST but i cant get the old oil filter out it's to tight..what else can i do? thanks.
Old Aug 29, 2008 | 04:17 AM
marragtop's Avatar
marragtop
What kind of oil filter wrench are you using?
Old Aug 29, 2008 | 01:18 PM
jasongt06's Avatar
jasongt06
If you cant get it out, you can take a screwdrive and hammer it threw there to give you leverage to turn it. It is a little messy, but sometimes it is the only solution.
Old Aug 29, 2008 | 02:06 PM
bradcdavis00's Avatar
bradcdavis00
I use one of those sheet metal punched out oil filter cover wrenches to get mine out. A 3/8" extension on my ratchet and it comes right off. They can be pretty tight.
Old Aug 29, 2008 | 02:47 PM
Steina's Avatar
Steina
CO River Rat
The chain-style works well, if you have room to swing it.
Steve
Old Aug 29, 2008 | 03:42 PM
dkf's Avatar
dkf
I use the stamped metal ones too to with a 3/8" ratchet. If you can't get it loose with that your going to have major problems. Sounds like someone used the wrench to install the filter, a no no.
Old Aug 30, 2008 | 09:44 AM
srercrcr's Avatar
srercrcr
They sell cast pot metal ones too.
