Sponsored by: Auxito
Camper Shell Wiring
Old Jul 1, 2000 | 09:44 PM
Roger_Dailey
Guest
Posts: n/a
Camper Shell Wiring
I'm trying to find a 12 volt always on power source near the truck bed. I need it to power dome lights in a camper shell. Thanks, Roger_Dailey(No Email Addresses In Posts!)
Old Feb 14, 2001 | 12:20 PM
98_xl_sport's Avatar
98_xl_sport
Camper Shell Wiring
I had the same problem and the (not the best, I'm sure) way I got around it was to tap into the dome light power located in the cab underneath the removable plastic plate on the passenger side. Use caution and be gentle when lifting it out or you may break it. You'll need a voltmeter to find the right wire to tap into. There is a drawback-the truck has a battery saver feature. After a certain amount of time (20 min?), you'll have to open one of the doors to get the light to work. You'll have to run the wire through a grommet back to the shell.
Old Feb 14, 2001 | 12:34 PM
98_xl_sport
Camper Shell Wiring
jdbobe
Dec 29, 2014 11:44 PM
ricochet
Electrical Systems/Wiring
Oct 28, 2007 11:28 AM
DBlazer
Aug 6, 2004 08:36 PM
doc_nomad
Mar 16, 2004 05:45 PM
killer4x4
13
Jan 26, 2002 03:03 AM
