General Automotive Discussion
Valve stem caps
Old Aug 26, 2008 | 07:02 PM
MikeB 88's Avatar
MikeB 88
Valve stem caps
Anyone have an idea if those caps that indicate tire pressures are very accurate. Saw some at the store the other day. The package claimed they would show an indication before a 5 pound loss of pressure.
Old Aug 26, 2008 | 08:15 PM
osbornk's Avatar
osbornk
I tried them and found them to no be very good. Also, they keep the valve stem open and I had to keep adding air to the tires. I threw them away.
Old Aug 26, 2008 | 09:12 PM
MikeB 88's Avatar
MikeB 88
I was thinking along the same lines about the stem being open. Glad I didn't spend the $10.00 on them, and bought the black plastic ones instead. I'm thinking of getting some with the Ford logo though.
Old Aug 30, 2008 | 01:48 AM
jim henderson's Avatar
jim henderson
I bought 8 of these. 3 or 4 had leaks so I took them back and still had a few leakers. I think some of the leakage had to do with getting them put on just right or maybe just pure luck.
However, I do have a set of 4 that finally have not leaked on my wifes car over 3 years or so and they do seem to work. When the green color is gone, they will be about 5 below rating.
I probably would not buy any more unless I found some American made ones or maybe from a quality outfit.
Besides, I kinda like using my tire guage and doing a walk around, makes me look like I might know something.
Just my experience.
Old Aug 30, 2008 | 02:34 PM
SuperSnake's Avatar
SuperSnake
Just get you some dice valve stem covers
Old Aug 30, 2008 | 03:36 PM
Autoglass's Avatar
Autoglass
Or,,,, maybe these????????
They even come with a wrench!
Old Aug 30, 2008 | 11:42 PM
dono's Avatar
dono
Gone but not forgotten.
A friend of mine has a Lexis that indicates on the dash the pressure in each tire.
Old Aug 31, 2008 | 07:07 AM
MikeB 88's Avatar
MikeB 88
Then I'd have to get wide white walls.
Old Aug 31, 2008 | 10:18 AM
XylemXorro's Avatar
XylemXorro
I have white caps that indicate nitrogen inside. Guess they were put on by Ford, don't really know. I'm surprised that no ones stole them yet. Knock on wood
Old Aug 31, 2008 | 10:47 AM
SuperSnake's Avatar
SuperSnake
Hey you might pull the look off.
Old Aug 31, 2008 | 07:25 PM
Lead Head's Avatar
Lead Head
Don't knock white walls!
Old Aug 31, 2008 | 08:47 PM
MikeB 88's Avatar
MikeB 88
Never, I have 2 1/2" wide white walls on my '69 Thunderbird!!!!
Old Aug 31, 2008 | 08:58 PM
Lead Head's Avatar
Lead Head
I think your gallery could use a couple of pictures of that car!
Old Sep 1, 2008 | 10:27 AM
jimdandy's Avatar
jimdandy
My friend just bought another 55 chevy. It had dice caps with wheel covers. He took the caps off and threw them away. His thinking was that if the covers came loose, they would be held to the wheel by the caps, and tear off the vavle stems. jd
Old Sep 1, 2008 | 05:37 PM
MikeB 88's Avatar
MikeB 88
Sort of makes sense with the dice caps. Don't have to worry about that with the Ranger. It has standard steel wheels and the hub caps are just big enough to cover the lug nuts!!
