Weak Idle, Hard hot start 2.
Old Aug 26, 2008 | 09:00 AM
chazb86's Avatar
chazb86
Hey everyone. I'm still trying to figure out the problem with my truck. So far what I've done is replace my the TPS, Temp. sensor distributor cap & rotor. code check which are 23, 63, 42. also changed the ICM. The truck idles fine now but after an drive about a mile the engine is hot it misss every time you give it the gas. I checked for any vaccum leaks and I poor water around the IAC and it started sucking air around the cap off end. Is it surppose to do this? I try it with the engine off nothing but when it's running you could here it when water is poored over it. everything seem ok. If that's not a problem then I will look at the fuel system.
Old Aug 26, 2008 | 07:48 PM
Franklin2's Avatar
Franklin2
Are you still getting the above codes? After you replace parts, clear the codes and check them again after driving it. If you still have TPS codes, then I would look for a wiring problem to the TPS.
Old Aug 26, 2008 | 09:16 PM
chazb86's Avatar
chazb86
Correction on the codes 23, 41 and 32, 25 KOER. 63 KOEO. 23 TPS, 41 HEGO LEAN, 32 EGR was changed with in the last 6 months. The TPS within a month. Do you know if the IAC is surpose to suck air from around the seal end?
Old Aug 28, 2008 | 07:54 PM
Franklin2's Avatar
Franklin2
There is never supposed to be unfiltered air going into the engine. If you still have the codes, you still have problems in those areas. A miss when you hit the gas does sound like a TPS problem.
Old Aug 29, 2008 | 10:46 PM
chazb86's Avatar
chazb86
weak idle hard hot start
Have a new TPS just need to put it on. I still have not had the question answered " Is the IAC surpose to draw air in from the capped end opposit the eletrical connection end?"
