Generator bad?
Old Aug 25, 2008 | 10:02 PM
justinfown1's Avatar
justinfown1
Generator bad?
ok so i went thru with the wiring diagram and re did the wire's under the hood a second time (since they got fried (a post just a few days ago) ) there were a couple wires out of place so i fixed all that about 99% sure the wiring is correct now. since i did that, it took care of the generator light being on however when i disconnect the neg cable the truck still dies. Am I wrong? a generator should be like an alternator right? the truck should run once started when the negative cable is disconnected from the battery right? Also there is a grinding/rubbing/brushing like sound coming from the generator that i did not notice before the wiring got fried. At the voltage regulator ( with truck running ) i used a test light and the only terminal to produce power was the BAT terminal (should this be?) also is there anyway to use a test light to see if the generator is working ( i don't have any way at the moment to get a multimeter)? thanks ....
