disc breaks squeak - horribly
Old Aug 25, 2008 | 01:50 PM
gweeds's Avatar
gweeds
I replaced the front pads and they squeal pretty bad at stops. Had the same problem before I replaced the pads, and hoped to get rid of it. Rotors looked OK, and I replaced the calipers (had leaks.) The squeaking is worse when I first start driving the truck, but gets better as I drive, but its still really, really bad. And I even put that "anti-squeak" goo everywhere that the package said to put it. Whats going on here???
Old Aug 25, 2008 | 02:01 PM
netscaner's Avatar
netscaner
The squeek goop is supposed to go between the back of the new pads and the piece the pads mount to.
Glazed rotors can cause squeeks and squeels. If they are shinny, deglaze them with emery cloth.
Old Aug 25, 2008 | 02:14 PM
quicklook2's Avatar
quicklook2
you should have the rotors turned.
Old Aug 25, 2008 | 05:02 PM
EPNCSU2006's Avatar
EPNCSU2006
Why should he have the rotors turned? Do they have too much runout?
Old Aug 25, 2008 | 05:15 PM
quicklook2's Avatar
quicklook2
if they were glazed from the leaking calipers then i would have them turned.
Old Aug 25, 2008 | 05:29 PM
danr1's Avatar
danr1
Yes I would also turn them, anything you can do with emery cloth would quickly be worn away again in seconds.
Wouldn't necessarily need lots of meat removed, if no run out or very little a light pass to correct the surface should prove to correct the problem.
Any competent machine shop should know exactly what to do to them and how to do it.
Generally takes 2 to 3 passes, first and second (if a second is needed) to remove the baulk material needed to true up any run out, one last light pass to etch the surface for the pads.
If they are badly glazed, enough to squeal and squeak they are likely to also be heat warped, at least a little.
Old Aug 25, 2008 | 05:57 PM
andym's Avatar
andym
Before you do that, what kind of pad did you use?
Merlin Miller
Jul 18, 2014 07:46 AM
Strokt350d
6.2L V8
Jul 2, 2014 06:53 AM
Shwan_89HD
Jan 24, 2012 05:05 PM
naiku
May 23, 2006 12:20 PM
myveryfirstford
Oct 26, 2005 09:49 AM
