Long time Ford owner, just happen to have a Chevrolet, Pick up, 1500 down in Honduras,, went to change oil,, while up on rack,, checking tires,, all turn freely,, except,, right rear, extremely hard to turn.. got home, re checked, jacked it up,, all turn freely except right rear, very hard,, need some advice on potential problem and and solution.. any help mucho appreciated.. thanx. B Slagle,, Msgt, USAF, Ret
Probably brakes. You didn't say whether it's drum or disc, but I'll assume drum.
The shoes are probably over-adjusted. There is a slot in the backing plate that allows you to adjust the shoes. Use a screwdriver and turn the star wheel whichever way is harder to turn. They should drag lightly all the way around the wheel when you're done.
Of course, if you've driven it around like this much, you've probably cooked the brakes and they will need to be replaced, so you might as well put new shoes on it too.
Question though - why register on a Ford site to ask a question about a chevy? Wouldn't it be easier to just find a chevy forum?
This truck has Disc brakes on rear also,, can they be adjusted like that??
Why use Ford Forum?? Lifelong,, 60 years, Ford owner,, just happen to get a good deal on Chev, ;and My son,, also Ford owner, referred me to this site,,Problem with that???
No, since it has disc brakes, you probably have a seized caliper that's sticking, or it could be the e-brake. I can't seem to remember what kind of e-brake it might use, is it a drum style or does it use a lever on the caliper? Either way, I would take it apart and see if there's anything obviously wrong.
I was just asking a question, so there's no reason to get defensive. I *am* trying to help you, after all...
If you haven't done this yet, drive it a mile or so, and then go check for heat at the brake, caliper, e-brake, axle housing where the bearings. Compare temps side to side, as there will be some heat there with normal operation.
But if you find, as I did on my van, you can bake bread with the heat off the wheel, you are closing in on the problem.
Thanx,, Everything is Cooking in Honduras,, about 90 degrees most of the time,, but I can't complain....Better not!!!My wife is in Iraq, constantly over clothed with all that stuff, and around 130 Degrees, with a rifle and about 50 Lbs on her back,, See why I can't complain?? would be ultimate Suicide!!
Thanx again,, now to learn how to free up a probably stuck caliper????
I am in Honduras, and I usually come out better If I know about how much the repairs, whatever it is, should be.. anyone can give me an idea of approximate cost to replace calipers.. ??Thanx
no idea about the calipers but fullsizechevy, chevytalk or 67-72chevytrucks all dot com would be the best people to ask as they have better knowledge of these animals.. I have trucks from all three of the us manufacturers and each has their plusses
Yes and no, because I do not know the style because you have not listed the year of your truck and I usually work on Chevy cars and not trucks. So, I can't look it up and see if it is the same style as on the cars.
People are saying "pads", like most Fords, but, does it only have one pad with a adjuster bar? Some times on the Fords (explorers etc.), the internal drum brake shoes can catch, but, I do not think the Chevy truck is that design.
For a dragging wheel and what is probably off road conditions, I would pull the wheel first and see if you have something caught in the shield/pad/bar. If anything is going to catch debris, it is usually the RR.
