sway bars?
Old Aug 25, 2008 | 08:26 PM
quaddriver's Avatar
quaddriver
Originally Posted by 85e150six4mtod
Doesn't your truck have a front bar stock? Almost everything has a front bar. The rears are the option, followed by bigger bars front and rear.
every 80-96 I have ever owned, and all the ones I worked on in this area had either all or none.
Old Aug 25, 2008 | 08:34 PM
andym's Avatar
andym
Yeah, same here, plus I've never seen a truck with just one sway bar on it, and in fact I owned at least one *without* a front sway bar.
Old Aug 25, 2008 | 09:30 PM
crestfallinman's Avatar
crestfallinman
i have front and rear swaybars,
is there a difference between the regular f150 swaybars and the lightning swaybars?
im just lookin for a bit more handling
and do polyurathane bushings make a big difference?
Old Aug 25, 2008 | 09:35 PM
quicklook2's Avatar
quicklook2
put the bushings on.
dramatic change in every vehicle that i put them on.
do the brackets at the same time.
lube them good with silicon gel.
Old Aug 25, 2008 | 09:53 PM
quaddriver's Avatar
quaddriver
prolly not new vs new, but in a few years when they dry out and crack, the rubber pull away from the bar, the poly is still tight.
Old Aug 25, 2008 | 11:05 PM
crestfallinman
my bushings are very dryrotted anyway so it will be a much needed upgrade thanks for all the help
Hamfisted
Jan 20, 2017 12:09 PM
fbergski
May 12, 2015 11:06 AM
DBLX
2009 - 2014 F150
Mar 23, 2014 09:53 PM
GearCrazy
Aug 29, 2011 11:32 PM
