Regulated Return Kit Problems
Old Aug 25, 2008 | 10:03 AM
DemonRace6's Avatar
DemonRace6
Hi!
I installed my Regulated Return Kit this weekend that I got from ITP. Looks great but I had a few problems along the way:
The rubber bushings used in-between the main supply and return line that connect to the bowl are a horrible design. They were extremely hard to get on and then the supply one leaked and I had to find a hose pin Pep Boys to match it and cut and shave it down to replace it, very annoying, they should just have been flair fittings, would have saved me a lot of time.
My batteries craped out, they are 7 years old and the stock ones that came with the truck but did they have to go now! .. not an issue with the kit just annoying.
The serious problems: My SES light is now on, anyone know why or how to resolve this?
Finally, when I started my truck after it sat for a full night after the first drive with the kit in I thought it was going to stall out, the RPM's were dropping from 1 to 0 over and over until I gassed it a bit and then it was ok, haven't started the truck this morning yet, hopefully that doesn't happen again but does anyone know what that was about!?!
But I must say I like the look of the gauge under the hood
Old Aug 25, 2008 | 10:25 AM
mndiesel's Avatar
mndiesel
I would recheck all the connections to make sure they are tight and not leaking. Also how much fuel pressure are you getting on the gauge? Try adjusting the pressure, I keep mine around 65-67psi. Otherwise call Dennis at ITP and I am sure he will help you figure it out.
Old Aug 25, 2008 | 10:37 AM
DemonRace6's Avatar
DemonRace6
Hi!
There are no leaks, that was the first thing I checked, my pressure is at 64psi, I will adjust that then call if it doesnt remove the SES.
Old Aug 25, 2008 | 10:57 AM
mndiesel's Avatar
mndiesel
Well 3-4 psi will not clear the ses light and with no leaks it must be non related to the reg return. Try to find someone close that can read codes and find out why the light is on.
Old Aug 25, 2008 | 11:21 AM
Orezona's Avatar
Orezona
Originally Posted by DemonRace6
I installed my Regulated Return Kit this weekend that I got from ITP. Looks great but I had a few problems along the way:The rubber bushings used in-between the main supply and return line that connect to the bowl are a horrible design. They were extremely hard to get on and then the supply one leaked and I had to find a hose pin Pep Boys to match it and cut and shave it down to replace it, very annoying, they should just have been flair fittings, would have saved me a lot of time.
IMO, I would contact Dennis at ITP with any issues or even suggestions you have/had with his RR kit. Dennis is a straight up guy very well known in the Diesel world. He will or would have helped you out in a flash.
Open forum bashing won't get you far with vendors. Just saying, not
Old Aug 25, 2008 | 11:30 AM
John311t's Avatar
John311t
Did you remember to plug your MAP sensor line in after installing the kit. You must have forgotten to plug something in, recheck everything.
Old Aug 25, 2008 | 03:34 PM
fbilly420's Avatar
fbilly420
That is exactlly what I was going to say.
I just installed this kit plus the bowl delete on my truck and I have to say the quality of all the parts I got from Dennis are top notch.
Old Aug 25, 2008 | 05:00 PM
ron's power stroke's Avatar
ron's power stroke
this is the very first time i have heard any thing like this...and there are a bunck of ITP R&R kits on this forum...if it was as simple as a flair fittings.. it probably would be that way...maybe it was the wrench turning the fitting??
Old Aug 26, 2008 | 07:58 AM
DemonRace6's Avatar
DemonRace6
Hi!
That is what Dennis said also, so I am going to have to look everything over again, I may have just bumped something else loose.
I was not bashing about the rubber bushing, just critiquing.
I did not mean to be bashing about the rubber bushing, just critiquing when still frustrated. I thought that the kit was extremely well put together, and the ITP parts look great!
Old Aug 27, 2008 | 01:33 PM
DemonRace6's Avatar
DemonRace6
Hi!
I found the plug, not sure which one it was but it was not pushed on all the way, SES light is off and my truck is running great.
Old Aug 27, 2008 | 02:18 PM
Orezona's Avatar
Orezona
Good to hear.
Shutech
Apr 21, 2015 09:31 PM
Banjoono
Jun 5, 2014 08:58 PM
FordeRXLT2005
May 2, 2009 02:27 PM
