Passenger side wheel
Old Aug 24, 2008 | 02:44 PM
rmalottwtes30's Avatar
rmalottwtes30
Ive never really paid attention but my passenger side tire leans out at the bottom. Anyone know what to look for to try to get it corrected? Thanks
Old Aug 24, 2008 | 03:23 PM
uncle.stosh's Avatar
uncle.stosh
Ball joint.
Old Aug 24, 2008 | 05:14 PM
srercrcr's Avatar
srercrcr
I don't see a problem based on the pic, but either way it's normal to have SOME tilt when sitting on the ground.
Old Aug 29, 2008 | 04:29 PM
rmalottwtes30
I jacked the wheel off the ground today and there is no play in the ball joints, actually they look like they have been replaced before. Is there any adjustments in the ball joints? It just seems to be a little more tiled than the driver side. Would bad shocks or leaf springs cause it?
Old Aug 30, 2008 | 09:28 AM
srercrcr's Avatar
srercrcr
Leaf springs? Is this in the rear?
If in the front, it sounds like it needs a camber adjustment.
Old Aug 30, 2008 | 10:14 AM
joestratton1's Avatar
joestratton1
some tire stores do a free alignment check, but i agree with stosh if there's a problem it'll be a ball joint or ball joint adjustment. if the previous owner replaced them or did a front end kit without having the truck aligned could cause problems
Old Aug 30, 2008 | 10:26 AM
uncle.stosh
Never mind.
Old Aug 30, 2008 | 01:00 PM
Piffery1's Avatar
Piffery1
A sagging spring can cause that.
