96 Explorer Won't start! Help Please
Old Aug 24, 2008 | 11:33 AM
rost495's Avatar
rost495
V6. High mileage but well taken care of. Most of the major components, IE alt, water pump etc except the timing chain replaced about 70K ago, it has 250K basically. Last reports from oil lab running synthetic showed nothing at all strange, and less wear than a 125K motor.
Ran fine, maybe just a touch hard to start, IE not instant but took a second or two to fire up.
Killed it at church this AM. Now just turns over and won't fire. Engine itself seems to vibrate in the mounts/frame heavier than normal?
All this in the middle of grandma dieing and teh funerla on Monday....
Any thoughts appreciated on where to look. Gotta get a chain and pull it home right quick.
Thanks, Jeff
Old Aug 24, 2008 | 12:54 PM
Lead Head's Avatar
Lead Head
Do you have fuel pressure and spark?
Old Aug 24, 2008 | 02:18 PM
rost495's Avatar
rost495
Tried it the cheap way, ether into the breather, and it'll run, so its gotta be the fuel pump is my guess?
Old Aug 24, 2008 | 02:26 PM
Lead Head's Avatar
Lead Head
Fuel pump or fuel pressure regulator. Since it fired on ether, that means the computer is getting a signal from the crank/cam position sensor.
There should be a schrader valve on the fuel rail, and you should just be able to rent or buy a fuel pressure tester relatively cheap.
Old Aug 24, 2008 | 05:31 PM
marragtop's Avatar
marragtop
Fuel pump should be your last resort. Check the fuel pump relay and the inertia switch. When you turn the key to ON, do you hear the FP prime for a second or two?
