Sponsored by: Real Truck
2008 f-250 engine codes
Old Aug 23, 2008 | 11:28 PM
bayou barataria's Avatar
bayou barataria
Can anyone tell me what the trouble code p-0446 is on an 2008 250 with a 5.4 ? Or can you point me in the right direction to search this site for a list, thanks.
Old Aug 24, 2008 | 08:46 AM
Johnny Langton's Avatar
Johnny Langton
P0446-EVAPORATIVE EMISSION SYSTEM VENT CONTROL CIRCUIT
This code was P1451 prior to '07.
JL
Old Aug 24, 2008 | 09:24 AM
projectSHO89's Avatar
projectSHO89
Your truck should be under warranty. A dealer will be able to diagnose and repair it for free.
Steve
Old Aug 24, 2008 | 10:13 AM
brownja's Avatar
brownja
Is that the $125.00 version of "you didn't tighten your gas cap"?
Old Aug 24, 2008 | 02:19 PM
bayou barataria
No, its the I cut the vent line to install a tee for my transfer tank version. I have since reconnected it , and it still throws the code and the fuel tries to back up the neck when I fill the tank. Before you ask, yes I checked the vent line and it is not restricted. What exactly is the deal with the engineering of this tank anyway?
Old Aug 24, 2008 | 08:21 PM
stewcon's Avatar
stewcon
Haven't you heard. "Ford has a better idea."
Old Aug 24, 2008 | 08:56 PM
projectSHO89
The fault code is an ELECTRICAL fault, not a vacuum line, etc problem.
Steve
Old Aug 24, 2008 | 10:38 PM
PowerStrokeHD's Avatar
PowerStrokeHD
P0446 - Evaporative Emission System Vent Control Circuit
Detailed Description...
Monitors the canister vent (CV) solenoid circuit for an electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified canister vent duty cycle by powertrain control module (PCM) command.
Possible causes...
VPWR circuit open
KAPWR circuit open (vehicles equipped with engine off natural vacuum (EONV) EVAP leak check monitor)
CV solenoid circuit short to PWR GND or CHASSIS GND
Damaged CV solenoid
CV solenoid circuit open
CV solenoid circuit short to VPWR
CV solenoid circuit short to KAPWR (vehicles equipped with engine off natural vacuum (EONV) EVAP leak check monitor)
Damaged PCM
Old Aug 24, 2008 | 10:40 PM
bayou barataria
I called auto zone and asked them to look up the codes, 0446 is something with the emissions solenoid and 0100 is something with the mass airflow sensor, but he wasn't very clear. Does anybody know how the emissions systems and fuel tank works? Thanks.
Old Aug 24, 2008 | 10:49 PM
bayou barataria
What is the kapwr, vpwr,and cv solenoid, eonv,and where are they? And why do we need all that crap on our trucks for? I'm sure there is a simpler way to control fumes from the fuel tank. Thanks for the info, you can always find someone who knows these things on this site.
Old Aug 25, 2008 | 12:54 PM
projectSHO89
You are in over your head.
Take it to the dealer.
Steve
Old Aug 25, 2008 | 01:07 PM
Johnny Langton
Steve
I agree.
JL
Old Aug 25, 2008 | 06:43 PM
bayou barataria
I reset the computer and it is o.k. now. Apparently the solenoid closed when it sensed a leak in the vent tube. I would still like to know what the abbreviations are for. I Have been working on cars for 26 years, I also rebuild old cars and sell them, I just am not familiar with the fuel vapor system on this vehicle.
Michael Covarrubias
Feb 6, 2017 11:20 AM
Pasta Prime
Nov 27, 2016 12:33 AM
Warren Hart
Sep 30, 2016 06:35 AM
SYS
Electrical Systems/Wiring
Apr 25, 2015 07:05 PM
Dogmann
Oct 9, 2014 11:48 PM
