Sponsored by: Real Truck
upfitter Switches
Old Aug 23, 2008 | 04:08 PM
4starcstms's Avatar
4starcstms
upfitter Switches
Hi all ...
I am wanting to put a set of the upfitter switches into my 04.. IIRC they WERE offered in 04 correct??? Or this is going to be a 05 up thing?? I asked while at my dealer recently, BUT he isnt hte brightest bulb in the place, while he showed me a set, I dont know if they were for a 04 or not.
I Do rember that he told me, they required the use of a control box..that the switches werent just switches.
Somebody wanna fill me in here? I know there are some really knowledgeable people, and even some that sell this kinda stuff, hanging around... soo...
Help!!! haha
Thanks!
Old Aug 23, 2008 | 05:56 PM
juneau76's Avatar
juneau76
I've been kicking this around for a while, too. Check out this thread from the tech folder: https://www.ford-trucks.com/forums/4...info-here.html. I believe it is for an '04. There are a couple other threads out there on it as well. I did read that a couple of guys got the '05 bottom dash piece that had the cutout for the switches. Sounded like a good idea, but I never saw pics after the install. Some day I'll take the time to do it.
Old Aug 23, 2008 | 08:23 PM
Help I M Stuck's Avatar
Help I M Stuck
here ya go...
Powerstrokeshop.com
Old Aug 23, 2008 | 08:38 PM
senix's Avatar
senix
upfitters switches for a 2008
Originally Posted by Help I M Stuck
here ya go...
Powerstrokeshop.com
Wonder if there is a place to pick up a set for the 08's?
Old Aug 23, 2008 | 08:54 PM
Help I M Stuck
this one..
Powerstrokeshop.com
Old Aug 23, 2008 | 08:58 PM
senix's Avatar
senix
thanks for the link
Old Aug 23, 2008 | 09:00 PM
Help I M Stuck
and some pre 04 install info..
Old Aug 23, 2008 | 10:01 PM
4starcstms's Avatar
4starcstms
Hmm Thanks 4 the info!
Old Aug 23, 2008 | 11:01 PM
Help I M Stuck
I need to order me a set for my truck
Old Aug 23, 2008 | 11:17 PM
4starcstms's Avatar
4starcstms
I need em for the train horn and to control the extra lights im planning to add over the winter ..
Old Aug 24, 2008 | 12:15 PM
riggz's Avatar
riggz
Keep in mind the upfitter kit isn't going to fit your pre 05 dash cubby. There will be some modification needed. I opted to go with the entire 05 lower dash upgrade.
Old Aug 24, 2008 | 01:06 PM
Help I M Stuck
hehehe..train horn...i just installed a big whopping one on my truck today..have it hooked to a momentary switch for now..just push the button..sure hope at least one of them switces is a momentary switch to use for the horn.
Old Aug 24, 2008 | 04:44 PM
4starcstms's Avatar
4starcstms
they are not. However you can take them apart to make them a momentary switch.. not to terribly hard.
how much of a PITA is it to change the lower dash??
Old Aug 24, 2008 | 11:18 PM
riggz's Avatar
riggz
It's not too bad to change out the lower dash. You will need to modify the plastic molding behind where the new dash piece mounts. It took me about an hour or so to get it all mounted.
