Engine Sputters after Warmed up under load
Old Aug 24, 2008 | 11:25 AM
reino134's Avatar
reino134
replaced distributer and ignition pickup this morning...........No Luck!!!
also swapped out the platinum plugs for motorcraft coppers. no change either
Old Jan 6, 2009 | 04:10 PM
hansgraf's Avatar
hansgraf
Did you ever figure this out? I am having what seems to be the same issue with mt 1990 f150 302. i am stumpped!
Old Jan 7, 2009 | 03:00 PM
reino134's Avatar
reino134
My 92 was a very early production, manufactured in Aug 91. Went back to advanced auto after I was almost positive it was a problem with the egr valve, and we compared a 91 to a 92 egr valve. They are just a little bit different. Installed the egr valve for a 91 and has been running like a top ever since. I hope this helps you out! I spent a small fortune til I stumbled across the real problem
Randy
Old Jan 7, 2009 | 04:42 PM
quicklook2's Avatar
quicklook2
great you solved it.
thanks for update.
Old Jan 8, 2009 | 11:39 AM
hansgraf's Avatar
hansgraf
Thanks
I just started to get the cel light at higher rpms and pulled the codes when i got home from work. Code 32. This indicates that the egr position sensor is out of range. Researching it a bit more I have found that could mean a malfunction EGR or the sensor itself. I believe it was on fordfuelinjection.com that I found that there are 2 different sensors. Match the colors of the sensor if you are replacing them. Apparently they read different values. I am going to the salvage yard this weekend to see if I can pick up a used EGR and sensor to try out before trying a new $150 EGR and sensor. I will let you know how this turns out.
Old Jan 8, 2009 | 05:42 PM
TNT1968's Avatar
TNT1968
I'm gonna try the EGR valve then. My truck is doing the same stuff and I've replaced a bunch of parts. Shows perfect with a vacuum guage too.
Old Jan 9, 2009 | 05:57 AM
reino134's Avatar
reino134
We discovered that I had the wrong EGR valve by counting the spring rings inside the valve. Count the rings in the one you take off and compare to your replacement
Old Jan 9, 2009 | 05:50 PM
TNT1968's Avatar
TNT1968
So far I've only replaced the sensor with no difference. I gotta use some penetrant on the nut on the bottom on the valve. I couldn't get it to budge even with a large pipe wrench! I'm afraid if I put it to it it'll break the threads off from the EGR valve inside the nut.
Old Jan 10, 2009 | 10:44 AM
zstangkrewson's Avatar
zstangkrewson
hey i got my issues with the 300-6 not having any power and sputtering!!! the injectors were clogged with rust that was building up in the fuel rail, take off your fuel rails and clean it out many times with brake cleaner, then gently blow and tap the rust deposits out of your injectors the re assemble, my truck is running crazy good right now, lol im happy, hope this helps some of you out!
Old Jan 11, 2009 | 07:12 PM
hansgraf's Avatar
hansgraf
Still there
So I replaced the EGR with one from the local pick a part. I cleaned it out as best I could and made sure it would hold a vacuum. After replacing the truck did run better, but the truck still stumbles a bit under load.
JFSFARM
Mar 12, 2017 10:16 PM
screaminford
1978 - 1996 Big Bronco
16
Aug 15, 2016 10:39 AM
robster1213
Sep 29, 2015 10:08 PM
deere842
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 30, 2015 11:54 PM
Mannix
Jul 23, 2011 04:27 PM
