High Mileage Oil:
Old Aug 22, 2008 | 08:40 PM
leonharu's Avatar
leonharu
High Mileage Oil:
If I switch to using one of those so called high mileage oils will it help my rear main seal leak in my 1973 F-100 with 360 engine? Has anyone tryed this type of oil? The engine has 180,000 miles with nothing done.
Old Aug 22, 2008 | 08:58 PM
ranger429's Avatar
ranger429
Help it what? Seal it up? I doubt an oil is going to make it go away or slow down the leak.
Old Aug 22, 2008 | 09:05 PM
montana_highboy's Avatar
montana_highboy
You can use a heavier weight oil to buy you some time but it's only masking the the real problem, you'll eventually need to change out that rear main seal.
Old Aug 22, 2008 | 09:09 PM
4x4 Bart's Avatar
4x4 Bart
There are a couple of company's that make additives that advertise to help rear main seals.
I have tried both on two different trucks and both times they worked. But as soon as you change oil the leaking starts back immediately and maybe even worse. It states on the label that it does not always work and the cost of bottle each oil change is a little expensive. I think its just a short term solution but worth a try.
Old Aug 22, 2008 | 09:26 PM
gearhed1971's Avatar
gearhed1971
Anybody ever try anything called a "sneaky pete"?Supposedly some kind of main seal replacement that you only have to remove the pan to do?
Old Aug 23, 2008 | 02:13 PM
Alvin in AZ's Avatar
Alvin in AZ
Leon, do us both a favor and ask about replacing your rear seal on the "FE" forum. :)
Pointy question...
Are you trying for some kind of record on that engine mileage? :)
I got mine overhauled at 148K and since then it is so sealed up and wastes
so little oil I can use Mobil1 15W-15 and not have to add oil for 7000 miles.
(usually go 6,000 tho)
It could never have done that since it was brand new.
The valve seals were crap right from the start! :/
Also, the engine has more power -and- gets better gas mileage than it ever did! :)
...252/252 CompCam, Edelbrock chain'n'sprockets and hard valve seat inserts added.
YMMV
Alvin in AZ
Old Aug 23, 2008 | 09:18 PM
fordman75's Avatar
fordman75
I've got a light duty 87 F250 with a 5.0L V8. The truck has 260,000 on the original engine ( never rebuilt ) . I run Valvoline max life and Lucas oil additive in it. The combination has helped slow down the leaks quite a bit. The engine uses/loses 1/2 a quart between oil changes.
Old Aug 23, 2008 | 09:27 PM
80F100man's Avatar
80F100man
My truck has 290,000 kms on it & doesn't use any oil, how about that guys? That's around 200,000 miles + Sorry, my Aussie spedo is in km/h .
Old Aug 23, 2008 | 10:36 PM
4x4 Bart's Avatar
4x4 Bart
A "sneaky pete" only works on a two piece seal. Not modern designed seals.
Old Aug 25, 2008 | 01:08 AM
Alvin in AZ
Cool! :)
That's around 200,000 miles + :) Sorry, my Aussie spedo is in km/h .
It's ok, "80" we understand it's tough getting stuff right being upside down and all.
--->302? 351? :)
"ford", me and Leon are talkin'bout old clunky "Ford-Edsel" FE engines,
...not newfangled whizzbang 5.0's. ;)
Alvin in AZ 360FE
Old Aug 25, 2008 | 02:48 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Good chance you have the old fashioned rope seal, if it truly is factory. They have a pin holding the halves in place, so they won't slip out. The newer style rubber seals-before the one piece new stuff, can usually slide out.
From what I remember.
Old Aug 25, 2008 | 03:59 PM
fordman75's Avatar
fordman75
Originally Posted by Alvin in AZ
Cool!
Alvin in AZ 360FE
I know he was talking about a FE. But he asked about high mileage oils. I was just giving my opinion of the oil I'm running in my engine. "4x4 Bart" was the one that said something about a one piece seal.
Leon if you are changing your oil anyways what would it hurt to try the high mileage oil? If it doesn't fix the leak it may atleast slow it down enough so you could live with it until you can replace the seals. But that's just my opinion. Just stay away from a full synthetic motor oil.
ol'yeller
Modular V10 (6.8l)
May 24, 2013 05:19 AM
advocate
1997 - 2003 F150
Feb 17, 2007 06:58 PM
grbr95
Oil & Lubrication
Sep 14, 2005 07:18 PM
biggreen4x4
Jan 9, 2003 10:02 PM
mooktank
20
Nov 22, 2002 07:42 AM
