1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2008 Ford NAV system in my 2005 F-350!
  #31
Old 08-27-2008, 09:48 AM
Supercab's Avatar
Supercab
Supercab is offline
Wink
I like the idea of a factory nav unit as well, think this will fit into a 1999??
Also, it looks like in one picture that there is a factory trailer brake control installed in what my '99 has as an open cubby hole.....I wonder if I could add the later factory brake control to mine??
  #32
Old 08-27-2008, 08:42 PM
Beerstalker's Avatar
Beerstalker
Beerstalker is offline
Sorry Supercab, but that is going to be a no on both accounts. Unless of course you have more money than you know what to do with.
  #33
Old 08-27-2008, 09:30 PM
naseflorio's Avatar
naseflorio
naseflorio is offline
I have the factory static rear camera in the mirror of my 2008. Does anyone know how to get constant power to that?
  #34
Old 08-28-2008, 07:51 AM
///M Puller's Avatar
///M Puller
///M Puller is offline
Originally Posted by FTX
My Backup camera monitor is powered by Upfitter #3
where is your monitor mounted? any pics?
  #35
Old 08-28-2008, 08:47 AM
FTX's Avatar
FTX
FTX is offline
I don't have the full schematics for the 08 yet, but here is how you can do it once you get the correct color code.
You can find the wire for the reverse trigger that goes up to your mirror. Easiest location will most likely be in the passenger floor side kick panel.
Cut that wire and install a diode on the "feed" side of the wire to prevent backfeeding of the new 12v power source. If not your reverse lights will come on whenever you engage the manual switch.
Next use one of the Upfitter outputs or a switch with 12v positive and run it over to the wire you cut. Then connect that along with the other end of the cut wire (going to the mirror) and attach those to the other side of the diode.
Now when you flip the new switch you will send the signal to the mirror to activate the monitor.
This is basic directions and of course there are many ways to accomplish this.
This is also assuming the wiring is similar to the reverse bypass on the factory auto-dim mirrors which is most likely the case.
Hope that helps,
  #36
Old 08-28-2008, 08:51 AM
FTX's Avatar
FTX
FTX is offline
It is over on the left of the cluster beside the a-arm pillar. I am installing my 08 Mirrors in the next few hours and will try to remember to take some pics of the monitor. My current location is actually a temporary solution, I am ordering a 2008 black factory overhead console and plan to mount a larger monitor I have laying around inside the flip down compartment lid of the new overhead console.
  #37
Old 08-28-2008, 09:14 AM
naseflorio's Avatar
naseflorio
Thanks FTX
  #38
Old 08-28-2008, 12:10 PM
RagdollRacer's Avatar
RagdollRacer
RagdollRacer is offline
I went to Kenwood site and I see the 7120 is "capable of Satelite Radio". All I want is a Big Screen Nav Unit with a regular radio (FM and AM) and a CD player (OK DVD as long as it also plays CDs) Am I missing something or am I asking too much? I am serious about getting one soon so I am looking for info on all my options.
Thanks for you help guys.
  #39
Old 08-28-2008, 02:01 PM
FTX's Avatar
FTX
FTX is offline
Here you go..
  #40
Old 08-28-2008, 02:11 PM
HeavyAssault's Avatar
HeavyAssault
HeavyAssault is offline
Did you have the dealer program the radio to work with your truck? I'm checking this out later today at the dealer to see what they say.
  #41
Old 08-28-2008, 03:04 PM
FTX's Avatar
FTX
FTX is offline
That is pretty easy ..once a dealer understands what to do.
The unit I got was completely unconfigured (see photos below) , so I found a 2008 truck on Ebay that has all of the options, NAV, Audiophile, Sat Radio, Aux Input, rear DVD system, Backup sensors etc. Using that VIN the dealer downloads an "As-Built" file from Ford then connects to my port and programs just the Stereo using that file. Only takes a few minutes to do. This is the same procedure as programming most new replacement controllers in the truck like ABS, Tow Command, etc..
The kicker is you must get the 290B connector so you can hookup the CAN bus wires (pin 15, 16 on 290B). Without those connections the dealer can't communicate with the NAV system and configure it.
Here are some shots of the Diagnostic Screen of the Factory NAV system along with the Configuration Status screen shots. FYI, You can access this area by holding down the 4 and 6 Preset buttons at the same time for a few seconds. It is amazing all the things that this unit can be programmed to do, the Hybrid Monitor section (HEV) is very cool.
  #42
Old 08-28-2008, 07:23 PM
HeavyAssault
Okay I got a source for the connector on the web. In fact they carry all three that will fit the radio. Where do I hook up Pin 15 & 16 to on our trucks? I don't see a 290b connector in my OEM '06 wiring diagram book.
  #43
Old 08-28-2008, 08:59 PM
FTX's Avatar
FTX
FTX is offline
On the back of the NAV system is 3 main connectors (excluding GPS and AM/FM antenna) The large one that is currently in your truck is 290A, the next one (16 Pin connector) is 290B, and the smaller one is 290C (subwoofer output) -See attached Connector Views
The closest location to tap into the CAN bus is the TOW Command Controller (if Equipped, if not you can use the instrument cluster connector). What you need to do is connect Pin 15 of C290B to Pin 6 (solid White Wire) of the left side Tow Command Connector C2142B(see pic) this is the "+" side of the CAN bus, then connect Pin 16 of C290B to Pin 7 (solid black wire) of C2142B, this is the "-" side of the CAN Bus.
The rest of the options you may want I am sure you can figure out from the attached diagrams.
BTW, it would be a great help for others if you could post where you sourced the Factory Stereo Connectors.
Hope that helps,
  #44
Old 08-29-2008, 12:25 AM
naseflorio's Avatar
naseflorio
FTX. I just installed the 2008 Nav System in my 2008 F-250. The two problems that I see are that the screen doesn't dim at night and the key lights do not come on when the lights are turned on. Is this something that I am going to have to take it to the dealer for or is their a function to turn these on that I am missing. Also I read your last post after I installed it and I didn't check to see if it had the 3 connectors in the 290 and the other one that you referenced. Is this something that you had to do because it is a 2005 model or is it any year model including 2008's that don't come with navigation? My truck came with just the plain single disc CD. Is this something that you think I am going to have to do if I take it to the dealer?
  #45
Old 08-29-2008, 01:20 AM
naseflorio's Avatar
naseflorio
Update: I went to the diagnostics screen and it looked pretty close to yours. Most things either not enabled or unconfigured. Found the day night options for the screen and they don't fix it. Also the key lights still do not come on when the lights are turned on. I got a ecu error also when I did the diagnotics. I think it was ecu. Everything else is working fine. I have determined that the dealer is inevitable so my question now is do you think I have all the pins needed in my 08 to communicate with the navigation. Keep in mind that I only had the single CD four speaker unit installed from the factory. Thanks in advance for your help and opinions.
Quick Reply: 2008 Ford NAV system in my 2005 F-350!
