Strange braking problem.....
Old Sep 1, 2008 | 07:02 PM
92Pony's Avatar
92Pony
Originally Posted by N8N
make sure you adjust your front wheel bearings properly, loose wheel bearings can knock the piston back into the caliper and cause a low initial pedal. might as well repack those bearings as well. also make sure the caliper is sliding side to side freely, uneven pad wear points to a bound up caliper slider
good luck
nate
I clean up and greased the caliper sliders when I put them back in.
Wade
octaneforce
Feb 18, 2015 08:10 AM
FortiesnBlunts
Dec 13, 2014 08:26 PM
OldWoodsDiesel
Jan 7, 2013 08:00 AM
hunter1897
1966 - 1977 Early Broncos
Jul 1, 2007 08:49 PM
