fuel tank selector
Old Aug 21, 2008 | 06:58 PM
topgunn's Avatar
topgunn
fuel tank selector
what is the best way to get to to it? it popped inside and I am trying to get to it ,to fix the broken bracket that holds it in. The plastic broke where the screw holds the bracket. Maybe I can glue the parts or put something to hold it in. I don't want to take dash apart any more than I have to. Is it easier to remove instrument panel or the bottom section?
Thanks Herb
Old Aug 21, 2008 | 07:10 PM
MatCat58's Avatar
MatCat58
In my 94 it's a simple as taking off the headlight switch **** and two screws behind trim strips, one on either side of the steering wheel the there are a few clips to pop out and the gauge bezel comes off enough to unhook the selector switch and electric 4x4 switch if you have it.
Old Aug 21, 2008 | 07:20 PM
topgunn's Avatar
topgunn
Is it the same for a 92 as I didn't see any screws?
Old Aug 21, 2008 | 07:23 PM
Wingman69's Avatar
Wingman69
You need to pop off the plastic trim strips one on each side of the steering wheel on the dash. The metallic looking plastic.
Old Aug 21, 2008 | 07:25 PM
MatCat58's Avatar
MatCat58
It should be the same for a 92 unless somebody switched the entire dash the screws are trim screws behind strips that you have to pop off directly below the headlight **** and on the other side of the steering wheel as well.
This page has an exploded view of the dash the strips you have to remove are labeled "14 and 15" and the picture shows the holes for the screws in the bezel behind them as well.
LMC Truck Parts - Page 42
