Rear end sagging a bit
Old Aug 21, 2008 | 03:11 PM
JohnnyFord's Avatar
JohnnyFord
I have a 1981 F-150 that was originally a 2wd but converted to a 4wd. It has the original leaf springs in the rear and a 4 inch block. The rear end has about a 2 inch sag and I am trying to figure out the best (and cheapest) way to correct the problem. I thought about adding another block to it, but figured out that was a bad idea to have stacking blocks. Does anyone have any suggestions?
Thanks for your help.
Old Aug 21, 2008 | 03:13 PM
1985 Ford F-150's Avatar
1985 Ford F-150
Id say your springs are shot get some new ones and that oughta fix er right up.
Old Aug 21, 2008 | 04:23 PM
nflfreak43's Avatar
nflfreak43
yeh get some new shocks, the old ones are definatly shot and it wouldnt suprise me if ur leaf springs were saggin some to so id go ahead and get an add-a-leaf while you were at it
Old Aug 21, 2008 | 05:55 PM
uncle.stosh's Avatar
uncle.stosh
Try some of this:
Old Aug 21, 2008 | 06:02 PM
Holmesuser01's Avatar
Holmesuser01
The 4x4 springs are probably taller than the original 2x4 springs. Replace the shock while you are at it.
Sometimes you have to give up and pay for things. Sure it hurts some, but when the truck is back together and handling better, you wont be sorry.
Old Aug 21, 2008 | 06:07 PM
uncle.stosh
Two cheap choices:
Used junkyard springs.
AAL's.
Old Aug 21, 2008 | 09:32 PM
Franklin2's Avatar
Franklin2
If you put a lift in an original 4wd truck, then you do have stacked blocks. The factory had about a 2 inch block, with a arm on it that goes up and hits a rubber bumper. If you buy a 4 inch lift, it comes with a block that you put on top of the original bumper block.
