Part number for intercooler intake
Old 08-20-2008, 01:53 PM
Aberasturi_c's Avatar
Aberasturi_c
Aberasturi_c is offline
Need the part number for the intake that I need to get from Ford to install my IC already got IC and tubes just need the intake. If someone can help with this.
Old 08-20-2008, 02:19 PM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
If you have the factory 2" intakes it will be for the early '99 made prior to 12-98.
Sorry i don't have the part #. I would call the dealer and tell them you want the early '99 spider pipe and you should get the correct one.
Old 08-20-2008, 06:36 PM
Aberasturi_c
Thank you what other possibilities would there be. Bigger than 2" or is the early 99 most likely gonna be right?
Old 08-20-2008, 08:45 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Here you are
Early ’99 Y-pipe: F81Z-6K889BA
Clamp (Y-pipe to 94-97 compressor): F81Z-8287DA or M/craft Service Part #YF-2488
2 Coupler (Y-pipe to 94-97’s 2” intakes): F81Z-6C640FA (2-3/8” to 2” reducer)
Clamp (I/C tube to I/C or Y-pipe) 1C3Z-6K786BA (hot side, floating bridge, constant
torque – spring under nut)
Clamp (I/C tube to I/C or Y-pipe) 1C3Z-6K786AA (cold side, floating bridge)<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 08-20-2008, 11:12 PM
Aberasturi_c
Thank you so the cooler tubes have the clamp on the cooler side already do I still need all the clamps. Sorry for the questions on this I just want to make sure that I have everything that I need for this install but at the same time dont want to spend unecessary money. Thank you once again. Reps sent
Old 08-22-2008, 12:44 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
OK, no problem, any time. Glad to help you. Thanks for the reps.
Dont say sorry for the questions; ASK anytime.
wtroger
2004 - 2008 F150
03-07-2012 05:53 PM
MagKarl
01-28-2008 11:31 AM
sonnylowe
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
08-04-2002 12:31 PM
Quick Reply: Part number for intercooler intake
