Clock Spring Sprung!!
Old Aug 19, 2008 | 06:34 PM
Fard's Avatar
Fard
Smile Clock Spring Sprung!!
My Cruise went out along with the horn, so I pulled the clock spring and ran a continuity test that checks out o.k. Anybody have a run in with this? If the clock spring is good what else could it be? all the fuses look good? thx
Old Aug 21, 2008 | 10:38 AM
dandy deke's Avatar
dandy deke
I had the same problem a couple years ago in my 94 e-150. This has been an issue with older fords. It cost me about 100.00 for the clock spring. The only real problem that I remember was fishing a wire through the column but not to bad if you have patience. Other syptoms of and on will be your dome light and radio.
