'05 explorer RSS not working right
Old Aug 19, 2008 | 12:45 PM
AngieT's Avatar
AngieT
I bought my '05 explorer about 3 weeks ago. I needed an extra key, so I took it to the dealership where I bought it and they made me a new one. After I left, I realized my reverse sensing isn't working properly anymore.
It's on when I start up, but as soon as I put the explorer in reverse, it cuts off. I called the dealership, but they said setting the code for the new key wouldn't effect the RSS. Is it just a coincidence that it stopped working the same day I picked it up, or is it possible someone cut something off while they worked on it?
I've not had it long, but I did enjoy that feature.
Old Aug 20, 2008 | 07:12 AM
AngieT's Avatar
AngieT
Just an update. I cleaned the sensors yesterday, but didn't make a difference. This morning when I leave to go to work, it beeps like normal when I'm backing out of the garage. But the first time I stop, and shift into reverse again....it toggles off. So it seems it's working intermittently. I have had someone tell me that it has nothing to do with the new key, but now I'm curious to the problem. I purchased the extended warranty, (high tech version), does anyone know if that will cover fixing the RSS.
Old Aug 20, 2008 | 10:41 AM
Steina's Avatar
Steina
CO River Rat
Angie -
If you have Ford's PremiumCare ESP:
"THESE ARE THE ONLY COMPONENTS NOT COVERED BY FORD ESP's PREMIUMCARE
MECHANICAL -- Service adjustments/cleaning; battery/cables; belts, hoses, brakes (front hub, drums, shoes, linings, disc rotors and pads); coolant; exhaust system (including catalytic converter); lights (bulbs, sealed beam and lenses); filters, fluids, lubricants; manual clutch disc; shock absorbers; spark plugs/wires; squeaks and rattles; tires; tune-ups; wheel balancing; wheel alignment; wheel studs; wiper blades.
EXTERIOR -- Service adjustments (glass and body parts); bright metal, bumpers, door handles, glass, moldings, ornamentation, paint, rust, sheet metal; sideview mirrors (glass/housing); water leaks; weatherstrip; wheel covers/ornaments; wind noise.
INTERIOR -- Buttons, carpet, dash pad, door and window handles, *****; rearview mirror (glass/housing); trim, upholstery"
Welcome to FTE!!!
Steve
6x150
2015 - 2020 F150
Dec 24, 2015 08:21 AM
Laserman
Sep 14, 2015 05:54 PM
Hardrock_F250
Jul 25, 2015 08:54 PM
ronbowling
Mar 17, 2015 01:14 PM
Alex from GA
Apr 27, 2014 09:04 AM
