Transmission Problem/Question!
Old Aug 19, 2008 | 12:32 PM
dnelson82's Avatar
dnelson82
Exclamation Transmission Problem/Question!
Hey everyone,
Been a while since my last post but I have recently ran in to a problem with my 2005 F150 Lariat Automatic truck. I have 104,500 miles on it and in the last 1000 miles, I have noticed a slight problem with what seems to be my transmission and 4th gear. When I am driving around town between 45 and 60 miles an hour and my truck is in the 4th gear, there is a slipping feeling (slipping like it is accelerating and then many bumps) in what seems to be my transmission. I have gone to the local ford place and called other transmission shops around town and they suggested flushing my transmission fluid. I ended up having this done and I didn't notice the problem for a few days and then it is now back. If I get the RPMs up high enough in 4th, I don't feel this slipping problem. So interstate driving is no problem. It is mainly a problem in town. What I have ended up doing is turning the O/D off so that my truck won't go into the 4th gear around town.
Does anyone have any suggestions as what to do or what might be the cause? Has anyone else experienced this?
Thanks and happy trucking.
D
Old Aug 21, 2008 | 07:07 AM
sandrat's Avatar
sandrat
Sounds like a possible Torque converter clutch fault, or maybe an igntion misfire. Have seen many coils fail ONLY at highway speeds w/ a load on it; more coils than trans faults. Have a shop check it for transmssion codes and check for a history of a miss.
Old Aug 21, 2008 | 04:33 PM
dnelson82's Avatar
dnelson82
Thanks for the reply. I originally was having a problem with my truck eating gas like crazy a few months ago and a sort of clicking noise coming from underneath my truck and it was the worst when I started my truck. I was also having my truck pull my boat at higher speeds on the highway. I put it in the shop and they ran a bunch of tests, checking for misfires and such, and they saw nothing wrong. It ended up being a crach in my exhaust manifold, random.
For my current issue, they told me to bring it in when it is having the problem and the tech will take it for a cruise. I am a little skeptical about that since when I was having problems because of my exhaust manifold, the first time I took it in, they said nothing was wrong. Right when I turned my truck on, the same noise was still existant. So, I brought the guy out to hear it and he was like, ohhh that noise. And they determined it was a crack in my exhaust manifold.
I will try to take it to another place in town and see what they say. It is realy annoying when just driving around town and I don't want it to do any further damage to my transmission, if that is where it is.
DN
Old Aug 21, 2008 | 05:07 PM
Bigtony4's Avatar
Bigtony4
Idon't know if this is the same type of problem or not but I had a 98 that did that. When ever I drove very lightly on the throttle it would shake. Once I gave it more gas it would smooth out. It was a coil going bad.
