lifted?
Old Aug 19, 2008 | 12:20 AM
samtye's Avatar
samtye
lifted?
i recently got a 80 f250 4x4 and i was curious if it has a lift or not. it sits as tall as my 76 highboy. do the 80's come this high or do you think it has a lift? there is blocks like my highboy in the rear. just curious.
Old Aug 19, 2008 | 07:21 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
do the front springs have a positive arc (like your rear springs) or a negative arc (look like they are sagging real bad)? There should be some factory blocks in the back, but only one 2inch(ish) block per side. if it has 2 blocks per side or a 4" block, then its lifted.
Old Aug 19, 2008 | 11:16 PM
samtye's Avatar
samtye
i guess the fronts have a negative arc, they're almost flat looking. and the rear blocks are probably around 2 inch. so if its not lifted is there two styles of 4x4's? because i saw one the other day and it wasnt this tall, but i guess i do have 35's on it.
Old Aug 20, 2008 | 03:10 AM
northern 7.3
body lift?
Old Aug 21, 2008 | 12:03 AM
samtye's Avatar
samtye
no, no body lift
