Transmission Question
Old Aug 18, 2008 | 06:30 PM
louisiana95ford's Avatar
louisiana95ford
I have a 95 f-150 two wheel drive 302 automatic. What kind of transmission do I have?
Old Aug 18, 2008 | 07:08 PM
mhg's Avatar
mhg
at the top of the page you will see a row of links
one says articles/specs
click and it will take you to al lot of info
look around and then click on the decoder link
it will show you how to decode your door sticker
Old Aug 18, 2008 | 07:17 PM
mwatvrider90's Avatar
mwatvrider90
if the trans pan has 14 bolts then its the 4r70w if it has more then its the e40d
Old Aug 18, 2008 | 07:32 PM
Dustin1690's Avatar
Dustin1690
Look at the door jamb find the transmission code and go to where mhg told you articles specs go to decoder right now ill tell you
Transmission code E is for the E4OD Electronic Four Overdrive
