truck/trailer wireing
Old Aug 18, 2008 | 12:23 PM
harley dude's Avatar
harley dude
76 f100 with 360. have 7 prong hooked up except for the wire to charge trailer battery when running.where would this be tied in to the truck? [altrenator,battery, etc ? thanks
Old Aug 18, 2008 | 02:22 PM
duste's Avatar
duste
Usually runs off the battery to a cct breaker then out to the plug on the truck. I use a 25 amp breaker on both the battery and the trailer brake cct and have never had any trouble, hope this helps.
Old Aug 18, 2008 | 02:45 PM
harley dude
traler hookup
thanks for the info. what gauge wire did you use?
Old Aug 18, 2008 | 03:06 PM
duste's Avatar
duste
I wouldn't use anything smaller than #12 and 10 would be better. 12 is whats in the 7 wire trailer cable you buy. I like a little overkill factor so I use 10.
Old Aug 18, 2008 | 03:18 PM
harley dude
trailer wiring
thanks again will go with 10 wire. do you disconnect the plug to stop drain on the truck battery when your parked? a guy can never have too many trucks. am doing a frame off on a 38
Old Aug 18, 2008 | 04:01 PM
duste's Avatar
duste
I always unplugged just to make sure the trailer didn't kill the truck battery. I don't have all those trucks currently, just the 79 460 and thats in the middle of a frame off as well. Is that a 38 pickup?? I just did a service call on my buddy's 34 Chev truck, throttle buttery broke off, what a freak.
Old Aug 18, 2008 | 05:59 PM
harley dude
yep 38 pickup. 8ba,isky max 1,offy heads and dual intake,reds headers with smithys, good winter project thanks for your info
