look in the drivers side rear compartment where the jack is located. you will need a mirror to see the label on the keyless module as it is located toward the front of the compartment
jim
I don't know where the module with the code is located on the Gen 4's. Did you look through this long thread to see if anyone posted info for your year? https://www.ford-trucks.com/forums/1...try-codes.html
If the info is not in that post then please add it in there when you find out. Thanks.
oops!
my bad-i read that as 97 not 07. on the 07 it should be in the right side c pillar trim panel area close to the second row seat but it is my understanding that ford has quit putting the lable on them so that you will have to go to the dealer and let then scan the system to get it for you.
jim
