Check Engine Lights/Instrument Lights
Old Aug 17, 2008 | 11:09 PM
BigNiner19's Avatar
BigNiner19
So I noticed a yellow/orange colored light that came on in the lower left corner of my gauge cluster. It kind of looks like a pipe fitting shape of some sort. Does anyone know what idiot light this stands for? EGR? CAT? Service Engine?
Thanks
Cory
Old Aug 17, 2008 | 11:54 PM
pb34's Avatar
pb34
Does it look like a wrench? If so that is the check engine light.
Old Aug 18, 2008 | 12:20 AM
BigNiner19's Avatar
BigNiner19
I wouldn't say it looks like a wrench. More like a pipe fitting believe it or not of some sort. Its the one down in the lower left corner.
Old Aug 18, 2008 | 08:20 PM
FordTechnician's Avatar
FordTechnician
What year and model truck?
Old Aug 18, 2008 | 09:20 PM
BigNiner19's Avatar
BigNiner19
2004 2 Wheel Drive XLT 4.6L
I found out it is the "emissions system" and after I disconnected the battery cable, the light has gone away. Not sure what may have caused it...EGR? CAT?
Cory
Old Aug 19, 2008 | 06:30 PM
jwillyf150's Avatar
jwillyf150
Its the check engine light cause mine did the same thing found small evap leak code P0442, kinda like finding a needle in a haystack to fix I just keep erasing it and drive on.
Old Aug 19, 2008 | 09:21 PM
BigNiner19's Avatar
BigNiner19
How are you erasing it, are you doing what I do and just disconnect a battery cable? I really would like to fix the problem.
Cory
Old Aug 19, 2008 | 10:09 PM
Capbyrd's Avatar
Capbyrd
sounds like you need a smoke machine
Old Aug 20, 2008 | 07:31 AM
Lariat Trucker's Avatar
Lariat Trucker
Make sure you tighten your gas cap. It sounds stupid but it's a minor thing that trips that light a lot.
Old Aug 20, 2008 | 10:29 AM
jwillyf150's Avatar
jwillyf150
Cory
I'm using a code reader I got from autozone. It tells you the codes and what they are then you can erase them. Unhooking the battery works just pain in butt.
Old Aug 20, 2008 | 04:06 PM
BigNiner19's Avatar
BigNiner19
Do you know exactly which code reader it is? Im interested in purchasing one.
Does it work with all OBII vehicles?
Cory
Old Aug 20, 2008 | 05:10 PM
jwillyf150's Avatar
jwillyf150
I just got the smaller handheld Actron OBDII scanner.
