walmart radio?
Old Aug 17, 2008 | 10:16 PM
Klau's Avatar
Klau
walmart radio?
Hello,
My daughter is now old enough to drive. Our 1996 F150 is acceptable for her to drive but the radio is caput. I have removed it, and now need a replacement. Walmart has an AM/FM cd player that also has an Ipod conection.....She would like that! How hard is it to put in is the big question. I have successfully installed a remote starter in our van without serious injury, so I think I may be up for this. (ignorance is bliss)
Any advice?
Klau
Old Aug 17, 2008 | 10:21 PM
fordguy300's Avatar
fordguy300
get wiring harness its all color matched and there is a mounting kit u can buy use pieces needed in kit to mount in the radio
goodluck
quicklook2's Avatar
quicklook2
i have 2 walmart cd players and love them.
get removal tool. (for those who do not already have radio out)
get wiring adapter.
get electrical tape.
less than a 1/2 hour job.
make sure she removes the faceplate every time she leaves the vehicle.
Old Aug 17, 2008 | 10:59 PM
john410312's Avatar
john410312
<TABLE cellSpacing=1 cellPadding=3 width="100%" align=center bg*************** border=0><TBODY><TR vAlign=top bgColor=#dddddd><TD class=spce width="50%">Constant 12V+</TD><TD class=spcel width="50%">Green/Purple </TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Switched 12V+</TD><TD class=spcel>Yellow/Black </TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Ground</TD><TD class=spcel>Black/Light Green </TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Illumination</TD><TD class=spcel>Light Blue/Red </TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Dimmer</TD><TD class=spcel>n/a </TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Antenna Trigger</TD><TD class=spcel>n/a </TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Antenna</TD><TD class=spcel>Right Front </TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Front Speakers</TD><TD class=spcel>5 1/4" Doors</TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Left Front (+)</TD><TD class=spcel>Orange/Light Green </TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Left Front (-)</TD><TD class=spcel>Light Blue/White </TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Right Front (+)</TD><TD class=spcel>White/Light Green </TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Right Front (-)</TD><TD class=spcel>Dark Green/Orange </TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Rear Speakers</TD><TD class=spcel>6" x 8" Side Panels</TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Left Rear (+)</TD><TD class=spcel>Gray/Light Blue </TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Left Rear (-)</TD><TD class=spcel>Tan/Yellow </TD></TR><TR vAlign=top bgColor=#eeeeee><TD class=spce>Right Rear (+)</TD><TD class=spcel>Orange/Red </TD></TR><TR vAlign=top bgColor=#dddddd><TD class=spce>Right Rear (-)</TD><TD class=spcel>Brown/Pink </TD></TR></TBODY></TABLE>
This came from www.the12volt.com
Old Aug 18, 2008 | 05:42 AM
quicklook2's Avatar
quicklook2
no mounting kit is needed for a 96.
do get the adapters.
Old Aug 18, 2008 | 09:37 AM
kaug23's Avatar
kaug23
I bought one of the cheap vr3 players that also takes SD cards and Thumb drives. They have a wireless remote that is OK to about ten feet, but it needs line of sight to work. I bought one for about 70 bucks almost two years ago to put in my boat (always in the saltwater) and it has held up so well that I put one in the truck as well. Your daughter will probably like the ability to play 2 gigs of mp3 music without having to carry 30 CD's around. Last I checked they are around 80 bucks now. Kurt
Old Aug 18, 2008 | 11:50 AM
skaterbro's Avatar
skaterbro
get wiring adapter.
x2 on everything except the electrical tape part. Use crimp connectors instead. More reliable connection, and it won't get all bunched up when you try to push the deck back in.
RadioShack.com - Cables, Parts & Connectors: Connectors & connectivity: Crimp connectors & terminals: 16-14 Gauge Insulated Crimp-On Butt Connector (16-Pack)
Old Aug 18, 2008 | 11:55 AM
skaterbro's Avatar
skaterbro
get wiring adapter.
Old Aug 18, 2008 | 02:17 PM
quicklook2's Avatar
quicklook2
i usually just solder and tape my connections.
the crimp connectors are excellent alternatives.
Old Aug 18, 2008 | 02:28 PM
quaddriver's Avatar
quaddriver
On the other hand, I put the AMFM Cass 'road king' in my tractor and it lasted one summer. So after a quiet year I got the AMFMCD road king and is seems to have issues.
Of course, it could be the brutal tractor environment (it is in the cab under the roof so its not like it is getting rained on)
I am less than enthralled with walmart brand radios (durabrand?) (aka built by chinese slave labor 14 hours before their organs are donated to wealthy europeans.)
Old Aug 18, 2008 | 02:48 PM
quicklook2's Avatar
quicklook2
then do not shop there.
pretty hard to find things not made in china anymore.
Old Aug 18, 2008 | 03:07 PM
McLeod's Avatar
McLeod
Something to keep in mind is that some Fords have the front speaker negative leads reversed.
To test this , connect your speaker wiring adapter.
On your wiring ADAPTER leads:
Touch the negative and positive leads of left speaker to a "C" or "D" cell battery. If you hear a pop, your truck is wired normally.
If NO pop is heard, connect the front speaker negative leads in reverse (left front speaker negative becomes the right front speaker negative).
This came from Crutchfield.
My 93 has reversed front speakers.
So have others: https://www.ford-trucks.com/forums/3...-speakers.html
Old Aug 18, 2008 | 05:25 PM
skaterbro's Avatar
skaterbro
Sorry for the double post guys, it's this stupid work computer.
I found that the Sony's at Wally World are pretty good, for the price that is.
Old Aug 19, 2008 | 02:53 AM
TexasGuy001's Avatar
TexasGuy001
This is a fairly easy 30 minute job. You do not need the mounting kit. I used one becuase it looks better. Definitly use the adapter that allows you to plug into your factory wiring. I like soldering and heat shrinking them. Another cool connector is a Posi Lock. They look sort of link the crimp connectors but use little threaded nuts instead and are reusable. I hate the crimp connectors, since they always seem to come apart.
Old Aug 12, 2010 | 09:45 AM
Kelson89's Avatar
Kelson89
Originally Posted by john410312
<table bg***************="" align="center" border="0" cellpadding="3" cellspacing="1" width="100%"><tbody><tr bgcolor="#dddddd" valign="top"><td class="spce" width="50%">Constant 12V+</td><td class="spcel" width="50%">Green/Purple </td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Switched 12V+</td><td class="spcel">Yellow/Black </td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Ground</td><td class="spcel">Black/Light Green </td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Illumination</td><td class="spcel">Light Blue/Red </td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Dimmer</td><td class="spcel">n/a </td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Antenna Trigger</td><td class="spcel">n/a </td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Antenna</td><td class="spcel">Right Front </td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Front Speakers</td><td class="spcel">5 1/4" Doors</td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Left Front (+)</td><td class="spcel">Orange/Light Green </td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Left Front (-)</td><td class="spcel">Light Blue/White </td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Right Front (+)</td><td class="spcel">White/Light Green </td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Right Front (-)</td><td class="spcel">Dark Green/Orange </td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Rear Speakers</td><td class="spcel">6" x 8" Side Panels</td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Left Rear (+)</td><td class="spcel">Gray/Light Blue </td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Left Rear (-)</td><td class="spcel">Tan/Yellow </td></tr><tr bgcolor="#eeeeee" valign="top"><td class="spce">Right Rear (+)</td><td class="spcel">Orange/Red </td></tr><tr bgcolor="#dddddd" valign="top"><td class="spce">Right Rear (-)</td><td class="spcel">Brown/Pink </td></tr></tbody></table>
I have a 95 F-150 xl and I tried to put in a Sony radio using this guide, I am haveing problems getting a constant power wire. I have checked all my fuses and come up with nothing, but for some reason I'm not getting constant from Green/Purple
