Need Timing help for F-100
Welcome to FTE.
If you want specific information about your engine, there is a spot on this board for just that. Go down the list to the engine forums and find the 6cyl board. Those guys will be more likely to be familiar with your set up. We'll try to help here too.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
rebuilding 1965 F-100 300 engine
with 480 cam
can anyone help me find some
specs for this?
Thanks
Bill in Dallas
