To do List
Old Aug 15, 2008 | 11:36 PM
TransplantX's Avatar
TransplantX
To do List
Okay guys, I have my work cut out for this weekend. As I am in the process of these things, are there any recommendations on things I should do, check or replace while I'm at it?
Here is my list:
Fuel pump
Water pump
VC gasket (found melted plug)
Possible IPR O-rings
GP's
Thanks in advance!
Old Aug 15, 2008 | 11:59 PM
spazinweasel's Avatar
spazinweasel
injector o-rings? while you got the covers off
Old Aug 16, 2008 | 11:25 AM
TransplantX
found first problem, first plug going into VC gasket is wasted. plastic around first pin is not even there. anybody have a part number for it?
Old Aug 16, 2008 | 11:47 AM
TransplantX
Okay, couple dumb questions... Is there a way to remove the dang leftside VC without moving the trans dipstick? Also, before i mess with any wiring under the VC, should disconnect the batts?
Old Aug 16, 2008 | 12:46 PM
884x4broncoII's Avatar
884x4broncoII
you should disconnect the batts before doing any work, it should be the first thing that you do. as far as the trans dipsitick i have no idea mine is a 5speed
Old Aug 16, 2008 | 02:01 PM
TransplantX
Old Aug 16, 2008 | 03:38 PM
BlueMule's Avatar
BlueMule
Well............You've probably got it off by now, but for the benefit of others who read this:
Start by peeling back the foil insulation on the A/C evaporator, that'll reveal the plastiv vacuum reservoir. Take out the two screws and move the res. out of the way and that will usually give you room to remove the VC. If you still have a hard time getting it around the trans dipstick remove the dipstick and stick a long screwdriver in the tube and use it as an extension of the tube. Push the tube toward the windshield to make room for the cover.
BTW that's the RIGHT side of the engine not LEFT
Old Aug 16, 2008 | 03:56 PM
TransplantX
Yup got it already, just loosened the bolt for the dipstick tube and that did it. But thanks for the other suggestion. Btw... you're right about what side, I was being a dips*%t and said the wrong side.
Old Aug 16, 2008 | 08:37 PM
firemanp's Avatar
firemanp
bluemule beat me too it.... the little vacum thingy has to go..
