96 Ford Bronco Wiring
Old Feb 3, 2002 | 01:50 PM
mjwhillock's Avatar
mjwhillock
Post 96 Ford Bronco Wiring
I have a 96 Ford Bronco with a small problem. The other day I was trimming some new carpet, when I finished my power locks, my speedometerm and my odometer had quit working. Also, my transmission would not shift smoothly. I checked to see if I had accidently cut any wires, but I hadn't (not that I could tell) and I also checked all of the fuses, diodes, and relays. Any suggestions as to what the problem might be? Thanks a million if you do.
Old Feb 4, 2002 | 01:00 PM
airharley's Avatar
airharley
Check the connectors under you carpet or at the door sills. Chances are you knocked a connection loose.
Old Feb 4, 2002 | 10:40 PM
mjwhillock's Avatar
mjwhillock
Thanks for the suggestion. I'll try that tomorrow. Maybe I'll have success.
Old Feb 5, 2002 | 10:00 AM
airharley's Avatar
airharley
