Lots of confusion on torque and anti-seize. When I did mine a week or so ago I set my wrench at 150in-lbs. When it clicked, I then did a SLIGHT tug. I used anti-seize also. I wouldn't think a 99 would survive 30ft-lbs.
I agree that 30 ft lbs is to high. I know krewat posted changes they did to the heads before going to a large thread count and one I think was to change torque (lower) at the factory during engine assembly.
I know the Haynes manual I have says 11 ft lbs (1999 - 2004 engine, 25 ft lbs 2005 +) but the workshop manual online says 71 - 106 in lbs (6 - 9 ft lbs)! That sounds way to low. I know when I did mine I went with 14 ft lbs and that just "felt right". I used anti-seize as well.
The big thing that worries me with 30 ft/lbs is when the engine gets very hot, like from a heavy load over a long period of time, the plug could pull the threads when the head expands.
Aluminum expands more than the iron plug, if the plug is in there that tight, there's just that much more force pulling on those threads.
I have the old '99 EVTM and it says 30ft.lbs. Must have been a change since then. I just did mine to 14 last night also. I had them tq'd to 30 ft.lbs. Damn EVTM, thats like the 4th thing that has been wrong on that CD so far. Guess I'll come here from now on.
