tranny swap
Old Aug 15, 2008 | 08:15 PM
j74250's Avatar
j74250
tranny swap
will an early 90's 5 speed manuel bolt to a 400m in a '79?
is there a non electronic overdrive that will bolt to a 400m?
Old Aug 15, 2008 | 08:43 PM
fastfarmer's Avatar
fastfarmer
5 speed from behind a 460 will bolt up to a 400.
Old Aug 16, 2008 | 07:56 AM
duste's Avatar
duste
Ford didn't make a big block overdrive auto till 87 and they were electronic shift. There is a computer module kit avail to put that tranny in an old truck for about $400. I plan on doing this mod to my own 460, I have the tranny but can't find time to work on my own stuff.
Old Aug 16, 2008 | 09:43 AM
tankrsc's Avatar
tankrsc
For the manual you will have to fab up some brakets for the Hyd. clutch also but should be well worth the effort.
Old Aug 17, 2008 | 02:34 PM
j74250's Avatar
j74250
Thank you for the info.
So the 400m is considered a big block?
as far as putting in a manuel trans, wouldnt the brackets and such out of a manuel trans truck work for the conversion for direct bolt on?
