Sponsored by: Real Truck
I read code p0174. now what?
Old Aug 15, 2008 | 02:54 PM
TractorM3's Avatar
TractorM3
I just read code p0174 from my SD. its a 06 w/ a 5.4 2WD 5 speed auto, XLT. i was towing about a 1500lbs trailer in tow haul mode and my engine light came on. Note there was no noticable engine preformance change. so i got home and hooked it up to my code reader and got that code with a caption "system too lean Bank 2"
now what? is one of my fuel rails really starving for fuel?
Old Aug 15, 2008 | 03:02 PM
redford's Avatar
redford
FTE Leadership Emeritus
I would start looking for a vacuum leak. Start by checking all your vacuum hoses under the hood, especially the ones going to bank 2.
Or.....if your truck is still under warranty get ot to a Ford garage ASAP.
Old Aug 15, 2008 | 03:19 PM
TractorM3's Avatar
TractorM3
haha warrenty? no it has 115k miles. ive had it a month now
Old Aug 15, 2008 | 03:56 PM
biz4two's Avatar
biz4two
Arrow MAF sensor, vacuum leak, or dirty fuel filter
Hope this info helps...
Technical Description
System Too Lean (Bank 2)
What does that mean?
Basically this means that an oxygen sensor in bank 2 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 2 is generally the side of the engine that doesn't have cylinder #1.
Note: This DTC is very similar to P0171, and in fact your vehicle may show both codes at the same time.
Symptoms
You will more than likely not notice any drivability problems, although there may be symptoms such as a lack of power, detonation (spark knock), and/or a hesitation/surge on acceleration.
Causes
A code P0174 may mean that one or more of the following has happened:
* The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters can cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
* There could be a vacuum leak downstream of the MAF sensor.
Possible Solutions
Possible solutions include:
* In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
* Inspect all vacuum and PCV hoses, replace if necessary
* Check for a dirty fuel filter and proper fuel pressure
biz
