first time w/biodiesel
Old 08-09-2008, 11:38 PM
chris mueller's Avatar
chris mueller
chris mueller is offline
Just bought my first tank of bio, by accident after months of searching for it. Found it at BP, noticed the pump label while I was filling up. The label stated it contains between 5 and 20 percent biomass derived fuel. I've read many times to expect a french fry smell from the exhaust, but you can't smell ANYTHING from my 6.0 now, unless you literally put your face in front of the exhaust stream. Is this because of the cat?
Old 08-10-2008, 09:59 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Welcome to FTE Chris! Below B-50 you'll probably won't notice any smell at all. I burn B-100 and everybody tells me mine smells like burnt fried chicken.
Old 08-10-2008, 09:19 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
B100 in my truck smells like hamburgers on the grill. man I get hungry driving with the windows down!
Old 08-11-2008, 12:40 AM
chris mueller
Thanx for the welcome. You think I should bother carrying an extra fuel filter, given the low concentration?
Old 08-13-2008, 08:52 PM
juneau76's Avatar
juneau76
juneau76 is offline
I would say better safe than sorry. I changed mine and most people say yes regardless of the amount of bio. It's your truck so technically your call, but you are doing yourself and your injectors a favor to change them.
Old 08-16-2008, 02:06 AM
chris mueller
Good point, and will do. FWIW, I've used diesel kleen, howe's, or redline at almost every fillup from the day I drove it off the lot (for lubricity rather than cleaning). I'm hoping that has kept little residue from getting a foothold in the fuel system. The filters I'm running now only have about 5,000 miles on them.
