dual tank sender problem
Old Feb 26, 2002 | 09:06 PM
mgm415's Avatar
mgm415
Have 1986 f250 with dual gas tanks. The front tank works fine.
but when using the back tank, the fuel gauge does not work. it used to then stoped. Would like to troubleshoot this problem.
how is it done, do they run a small current thru the sender? is the sender just a resistor? Have the book but no info on dual tanks.
thanks
Old Feb 26, 2002 | 10:14 PM
Mil1ion's Avatar
Mil1ion
Do you still get fuel to the engine from that tank that the SU doesn't work on?
If so, the problem is in the Sending unit or the the ground for the sending unit. To confirm, go to the sending unit and attach a test light to the power connector ,then get someone to turn the key on,if there is a pulse of current at the connector the problem is definitely the SU or its ground.
There's your troubleshoot.
If you didn't still get fuel from the tank it would mean wiring problems.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 27, 2002 | 02:13 PM
Franklin2's Avatar
Franklin2
You can also take the wire off the sending unit in the back, and with the ignition key on, and the fuel switch in the rear position, take the wire that goes to the sending unit, and ground it to a metal part of the frame. Then take it off the ground and let it hang in the air. Everytime you do this the fuel guage should sweep back and forth. This will tell you if your wiring and fuel switch are working correctly.
Old Feb 28, 2002 | 11:17 AM
Mil1ion's Avatar
Mil1ion
f100beatertruck
Sep 15, 2013 09:22 PM
PRIMERED79 SHORT BED
Sep 5, 2013 09:52 PM
catbird7
Sep 27, 2010 02:19 PM
924x2150
18
Aug 29, 2005 09:49 PM
arguenaut
Jan 19, 2005 11:51 AM
