Two dead injectors???
Old Aug 13, 2008 | 09:53 PM
matt95stroker's Avatar
matt95stroker
Exclamation Two dead injectors???
I haven't started my truck in a while and the injectors have been removed and reinstalled. Anyways, After filling the hpop and pulling the fuse yadie yada yada, it starts everything seems fine until I noticed a bad vibration so i jumped out of the truck and started checking things out. The two front injectors on the driver side weren't spitting out any oil. I started by swapping injectors, same condition on the same cylinder. Checked the wires from the plug at the injectors all the way to the IDM. I also checked for broken pins, although I did notice what looked to be a little bit of corrosion. Maybe just an air pocket???
Also what would be the best way to clean the inside of the plugs?
Thanks for the help guy
