AC will not work
Old Aug 12, 2008 | 02:31 PM
nibot's Avatar
nibot
AC will not work
Hello,
My compresor will engage for about 5 minutes, then shut off, If I turn the unit off and re start, it will do the same,
Old Aug 12, 2008 | 02:49 PM
quicklook2's Avatar
quicklook2
helps to put what truck, engine, if it ever worked, etc.
Old Aug 12, 2008 | 02:56 PM
nibot's Avatar
nibot
Sorry,
1989 F150, 5.0, Yes it did work fine, and has been re charged.
Old Aug 12, 2008 | 02:59 PM
IreallyLikeFords's Avatar
IreallyLikeFords
Sounds like low pressure to me but if you say its been re charged... I would verify that is has the right pressure.
Old Aug 12, 2008 | 03:14 PM
nibot's Avatar
nibot
Thank You.
Old Aug 12, 2008 | 04:04 PM
quicklook2's Avatar
quicklook2
r12 or r 134.
did you evacuate and then recharge it?
did you recharge it?
why did it need it?
Old Aug 12, 2008 | 04:23 PM
nibot's Avatar
nibot
It has R136 ports (aftermarket) on it,
I can not answer the rest of the questions I just purchaced the truck about a month ago.
Old Aug 12, 2008 | 04:41 PM
quicklook2's Avatar
quicklook2
i always recommend taking it to a professional air conditioning place with info like yours.
