Rough idle, Error codes P0171 and P0174, Please HELP
Old Aug 12, 2008 | 11:11 AM
ejkob's Avatar
ejkob
I have a 2000 explorer V6 4.0l SOHC, sport with 170K miles . Last year the check engine light came on and after a FORD inspection, was told by that the manifold gaskets were leaking. OK, I get them changed and the codes continue to appear. I have relplace both O2 sensors, the MAF, the IAC and I still get the codes. ON top of that, the engine at idle seems to search and fluctuates around 400 to 700 RPM! It sounds like a vacuum leak, but I cannot find one.... Where should I look next? Could it be a fuel problem? It runs fine outside of idle even pulling my boat? It it the DPFE or could it be the ECT. I have also replaced the computer too. Please advise as this is driving me nuts!!!
Old Aug 12, 2008 | 12:25 PM
87 XLT's Avatar
87 XLT
Not sure, but I think the SOHC has the PCV valve at the rear of the engine with a hose coming in from both sides.
Have you checked for a leak in one of these hoses?
Old Aug 12, 2008 | 01:16 PM
ejkob's Avatar
ejkob
Actually no now that you mention it, but I will. Thanks
Old Aug 12, 2008 | 02:13 PM
srercrcr's Avatar
srercrcr
It's a small plastic PCV, not even my Ford dealer knew where it was, and I haven't found a parts store who sells it. It differs from the OHV one.
acm05fsu
1997 - 2003 F150
Dec 26, 2019 02:24 PM
nuts4hotwheels
General Automotive Discussion
Aug 9, 2010 05:26 AM
ghardy7605
Oct 14, 2009 07:06 AM
bigron
Aerostar
18
May 14, 2008 07:50 AM
majboise
Apr 7, 2004 09:43 PM
