Fuel Pressue Gauge
Old Aug 11, 2008 | 09:22 PM
jhand124's Avatar
jhand124
Fuel Pressue Gauge
I did a little modding after work this evening, I put in a ISSPRO fuel pressure gauge. Everything went well, pressure is at 65 PSI with no shim. I haven't taken her for a ride yet, I will do that on my way to work tomorrow. I took some pictures though.
Here is the gauge installed in the dash.
This is the fuel Isolator
Connections at the fuel bowl
Old Aug 11, 2008 | 09:29 PM
PaysonPSD's Avatar
PaysonPSD
Nice job Jason. Did the gauge supplier also supply the fuel line to the isolator? Who did you get the gauge and isolator from?
Old Aug 11, 2008 | 09:32 PM
jhand124's Avatar
jhand124
Originally Posted by PaysonPSD
Nice Job Jason. Did the gauge supplier also supply the fuel line to the isolator? Who did you get the gauge and isolator from?
Diesel Manor is where I purchased the gauge, you can buy the kit for in cab install so it comes with the isolator and fittings, the braided line and fittings is sold separately.
Old Aug 11, 2008 | 09:39 PM
empiretc's Avatar
empiretc
yep, i like they way the gauges look installed like that.
it sucked that mine needed spacers in that location, but I don't think they look too bad. in the pic below only the one one the left had the spacer, but now they have one.
my fuel pressure would sit right at 68 psi. it has been at 70 since i have started running homemade b80 in it.
Old Aug 11, 2008 | 09:44 PM
jhand124's Avatar
jhand124
Did you need a spacer for clearance? I just modified the gauge mount a bit.
Old Aug 11, 2008 | 09:46 PM
4inchlovin's Avatar
4inchlovin
Anyone know who it is that has the like 15+ gauges in his cab???
Old Aug 11, 2008 | 09:49 PM
jhand124's Avatar
jhand124
CSIPSD, Joe AKA the Gauge
Old Aug 11, 2008 | 09:51 PM
empiretc's Avatar
empiretc
Joe (CSIPSD) has 16 gauges.
yeah, the gauges are kind of long so they needed something. the gauges didn't come with any kind of mounts. i figured I would eventually buy the in dash pod, but that hasn't happened yet.
Waltdog
25
Dec 29, 2010 04:48 PM
morgan867
2009 - 2014 F150
56
Jan 1, 2009 02:59 PM
uc4me
Jan 28, 2008 08:26 PM
i eat hybrids
Jan 12, 2008 07:07 PM
fordloverf2501970
Iowa Chapter
19
Aug 31, 2004 06:40 PM
