has any one changed out there tranny cooler
how did you do it, was it easy
the reason i ask is iam putting a new tranny in and thought it would be a good idea to put in a new cooler at the same time with a inline filter as well
thanks
just did a 6.0l trans cooler on my 7.3 four bolts drop the new one in 4ft of trany hose and two fittings 3/8 to 1/2 a couple bottles of atf. i give it a 1hr and a beer. i'll find out later this month when i pull the the 5th
I installed a 6.0 cooler, and have been very happy with it. Very easy job, and it is well worth it. It has been a great help with lowering tranny temps while towing the 5er.
WTH kind of site is that??? It's just a bunch of links to other retailers.
Most discount Ford parts dealers will sell the 31-row cooler for around $300. Definitely worthwhile; kept my tranny down below 150ºF where it used to touch 180ºF on the highway.
I bought my cooler from an online Junk Yard. I finally got the right cooler after about 3 weeks. I guess I shouldnt complain, I got for 100 bucks, But it was a nightmare. If I had to do it over again, I would call Ed Th!nk Parts Guy
With a Tru-cool I don't see temps above 190deg even when towing even on some steep grades! I'd call it a 2 beer job. Not hard at all....
12 pack job when I did the 6.0 cooler.
gather the parts
beer
make sure you got them all
beer
start the disassembly
beer
beer
dispose of old parts
beer
beer
reassemble the cooler
beer
beer
check for leaks with engine running
beer
Fill trans to right level
beer
put all parts back
beer
clean up tools
beer
I have the tru cool and no complaints. If I was doing it again I would go with the 6.0 cooler and remove the little stock one. That way there is less hoses under the hood going to and fro. I just noticed the line off of the cooler to the tru cool is starting to crack a bit yesterday. Not too happy with that.
