So i think that im finally going to bite the bullet and buy a new turbo and injectors. Im thinks stage 2's from Rosewood. Now for the question(s), is the H2E a BB turbo and is is a bolt in kit if i where to get it from say Beans? Am i going to have to go to a bigger HPOP like a terminator or stealth to run an H2E reliably or would a 17* be ok? My biggest concern with the D66 is that is wont be as reliable as the H2E and i can't have any down time on my truck with winter coming. I had a couple other questions but i cant remember them right now. Thanks in advance.
H2e is more complicated, but if you buy the mounting kit it's essentially bolt in from what i hear.
D66 is direct replacement.
I'm pretty sure both are foil bearings.
D66 will handle 2's, but it's at it's top limit.
17* HPOP will handle 2's, but you may get a CEL at WOT and high R's for low oil pressure, but it'll go away afterwards from my understanding.
