I installed PowerSlot rotors and HAWK LTS pads back in April '08...and I have been very happy with the performance. The front have no fade...are quiet...and good quality.
So...a very "Positive" experience thus far.
TIP: Make sure to clean and lube the slide pins...
The difference between the two is the temperature in which they operate best at. One likes to run a little cooler, which will give you better braking if you're not in them alot. This is the type I settled for and they do require some temperature to work nicely, two-three slow stops usually does the trick. The other type is the "high performance" and it requires a lot of heat to work properly. You need to get the pads warm and keep them warm. This type is usually best left to dedicated towing and autocrossing.
