Damn these things!!!
Old Aug 11, 2008 | 02:34 PM
7866ford's Avatar
7866ford
78 F-150 4x4 on 35 in. BFG M/T's. This damn thing is eating wheel bearings. I've put in three sets in 4 months. Any suggestions on something that could be causing this. I put the high dollar bearings, with some high dollar grease. i've put them in my buddies trucks a hundred times and no problems, with bigger tires. What could cause this before i kick this F$%#@&g thing off the jack stands.
Old Aug 11, 2008 | 03:35 PM
75F350's Avatar
75F350
What is the condition of the spindle / wheel bearing nuts / retainers?
Those might be coming loose, and messing up the works.
Are both sides doing the same thing?
Old Aug 11, 2008 | 06:21 PM
cykoticford's Avatar
cykoticford
my buddy had a similar problem it turned out to be the hub was messed up and when you put new races in they were cocked a little bit he would drive it for about 3 weeks and it would eat the bearings it was hard to find up in the air it would spin real nice. hope that helps
Old Aug 11, 2008 | 07:06 PM
7866ford's Avatar
7866ford
just put in a new spindle, races with bearing, wheel seal, and both new axle nuts. So far so good. I appreciated the input. Its just the drivers side, so i hope all that new crap works. I appeciate the input, anymore ideas are welcome.Thanx!!!
