Edelbrock Carb Issues
Old Aug 11, 2008 | 12:47 PM
kmunson's Avatar
kmunson
Hello everyone,
I've been reading the forums here for quite some time, but this is my first post. I have a 76 F100 with a 390 and an edelbrock carb. I recently converted the carb to electric choke and I'm having trouble getting things to work correctly. Here's what happens. When first starting the truck, the carb works great. It starts right away and idles nice. A quick tap on the pedal and the fast idle comes down to "normal" idle. BUT (there's always a but) the truck won't start after that. The choke valve closes all the way and floods the carb. I have to manually open the choke valve for things to work again. I think this problem has something to do with the fast idle, but I'm not sure. There's current at the new choke, the choke seems to be set properly according to the instructions. I'm baffled. Any suggestions? Thanks in advance.
Old Aug 11, 2008 | 12:59 PM
fmc400's Avatar
fmc400
MSEE
Hi kmunson, did you remember to ground the choke cap? Unlike stock carbs, the Edelbrock choke has a separate ground tab. Usually just grounding it with a small jumper wire to one of the three choke cap retaining screws will work fine.
Secondly, you may want to make sure the choke spring is actually engaging the tang on the linkage, inside the choke cap housing.
Old Aug 11, 2008 | 02:46 PM
kmunson's Avatar
kmunson
Thanks FMC400. I appreciate the suggestions. I do have the choke grounded to one of the cap screws. I also have the tang engaged; it may just need to be adjusted. I appreciate the suggestions.
Old Aug 11, 2008 | 06:04 PM
saleen065's Avatar
saleen065
Sounds like you have the choke set too tight. ie: spring tension is too much and not opening up enough.
