Freak the EEC??
I have purchased a 1988 F-250 with a 460 with a C-6 tranny. It needs a rebuild or a new motor. My question is how far can you go to build more horsepower with the Ford EEV-IV fuel injection system? I bought this truck to pull a trailer on the highway and I think the stock 230 HP with 390 Lb/Ft of torque is a little weak for this large of a motor. I currently have a 1971 460 block (D1VE) with a set of 1973 heads (D3VE). I'm fairly sure the block is the same and will bolt right in. I get a little fuzzy on the heads though... I know they are larger 2.09 intake valves with a smaller 92CC combustion chamber. I would like to use these heads and go with a larger towing type cam simply to make it breath better and make more HP. I do plan on putting on a set of headers and making sure the oxygen sensor goes back in correctly for an accurate reading. Does anybody out there know of a good compression ratio and cam set up that I can use without freaking this thing out (I'dl like to make about 400hp)? Do you know if I can even use this block and set of heads with the EEC-IV? Anyway maybe this will be the start of a good thread. If anybody has any good thoughts or input please let me know. This will probably lead to a few more questions...
I do have some good experience with motors but only hot rods. This stock type motor stuff is a bit new to me. The fuel injection doesn't scare me and I would like to reuse it only becuase it runs the motor fine now and that is just less money to spend in the long run. I'm not opposed to putting in bigger fuel injectors if necessary or putting on a larger throttle body but that is about all I would care to do (short of buying a Holly 850 double pumper and putting electrical tape over all the lights that light up on the dashboard).
Below is a link to my more serious1974 F-100 521 cid race truck. This is what I pull with my new truck that is in need of a motor. Any and all help is appreciated. Thanks everybody!!
www.MrScharfenberger.com/F100
I'll be watching your progress, good luck to you.
Summit Racing - High Performance Car and Truck Parts | 800-230-3030
to compare prices. You have a ton of options to get whatever compression you want if you're getting new pistons.
I had not heard of problems with HV oil pumps, but I'll be asking around for sure. On a small block Chevy I had years back the lifters were just starting to tick a bit at 70k so I grabbed a HV pump, got another 95k out of that motor before I sold the thing running perfectly. So I automatically wanted the HV pump while I had the 460 open. Thanks for the heads-up.
