Do you really need a sealer
Thanks
It mostly depends on which type of clear the color is made from ,, some types of balancing clears need to be re -formulated ,,
If you have enough paint ,,& aren't blending ,,,all colors , other than candy's are opaque,,,,
I have Never needed to seal a car ,for color consistancy ,,ever ...If you are trying to use less paint ,,start out with a primer that is close to the color you are painting ..If not true ,,you would never be able to blend within a panel....& it can be done ,even with a 3 stage.
In 35 years ,I have never had prime Or sealer coat show through the color ,or affect the out come,not one single time ....
I do argree with Kenseth on this point , (actually more than just one point ,,but for now,),sand it & shoot it,,,use a good quality paint .
If you are aiming for show quality ,,start out with No paint ,,then the are absolutely No issues
If the vehicle is factory paint ,,there will not be any bleed through issues...
Painting over partially primed areas ,,will bring up some problems (swelling ,crazing ,bulls eyes , ect) that can only be avoided by stripping ,or allowing everything to dry completley(all solvents out),,or stripping ...then only dealing with the surfacer drying time
Make sure ,before you prime ,,that the primer never extends past the area you have preped ,,(320 or 400)
never put prime coat over shiny paint ,,the top coat will seep under the edge of the primer & cause swelling ...
But in our business ,,time is a luxury no one will afford us ...
bbbrrriinnnggg,,,"when's my car gonna be done ? "
"Well I was working on it ,,then the phone rang"....
