Volt guage hook-up
Old Apr 2, 2002 | 11:50 PM
Mil1ion's Avatar
Mil1ion
Volt guage hook-up
Old Apr 17, 2002 | 10:56 AM
Ford79's Avatar
Ford79
Volt guage hook-up
I'm installing new guages in my truck and have a quick question. Where do I hook the + terminal on the volt guage to? What should the wire be hooked to to be more specific?
Thanks.
Old Apr 18, 2002 | 06:28 PM
Franklin2's Avatar
Franklin2
Volt guage hook-up
A handy place nearby is usually the cigarette lighter wire.
Old Apr 19, 2002 | 09:29 AM
76supercab's Avatar
76supercab
Volt guage hook-up
The cigarette lighter wire is an unswitched source. Meaning that the voltmeter will be reading voltage whether the truck is running or not. Over an extended (probably verrrry long) time this could drain the battery. I would select a switched source. I used the lead for the radio for the aftermarket gauges in my Mustang. I also used .175 diameter bullet connectors (there are smaller ones that won't fit) to plug into the stock harness without cutting it.
Old Apr 19, 2002 | 10:24 AM
Ford79's Avatar
Ford79
Volt guage hook-up
Thanks for the help guys. I had a big mess when I was installing the guages (on the dash of my 78 F-150) and I am in the process of reassembling it. I'll look for a switched source under the dash to hook it to. Probably the same wire I hooked the stereo to. Thanks again.
Old Apr 19, 2002 | 10:48 PM
Franklin2's Avatar
Franklin2
Volt guage hook-up
Whoops, messed that one up! Thanks for correcting me.
