fixed the return lines
Old Aug 9, 2008 | 05:41 PM
beerman2therescue's Avatar
beerman2therescue
I have fixed my return lines. I put on the new orings and the plastic caps are on tight.I just started the old girl up and damn thats some serious smoke.What did I do wrong? help please
Old Aug 10, 2008 | 04:37 PM
goodB0Y's Avatar
goodB0Y
how did you go about fixing the return lines?
Old Aug 10, 2008 | 04:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How long did it smoke?
What color was the smoke?
Old Aug 10, 2008 | 07:09 PM
beerman2therescue
I started it and it ran for about 2 minutes,I stopped it after the cold start solenoid turned off.The smoke smelled like fuel.I checked my connections and they seem to be nice and tight. No fuel was visible as well.
I am in the process of rebuilding the old girl. I have the whole interior out of it. I am having the seats redone and new carpet is coming in this week.I was thinking of changing my injectors because I have no idea when they were last replaced.
On a side note. The truck really needs the glowplugs to run for a few extra seconds for it to start, even when warm.I live in florida I shouldnt need them but a few times a year.A little help from the experienced would help.
Thanks again
Old Aug 10, 2008 | 08:24 PM
Dave Sponaugle
An IDI in good shape, excellent starter and batteries, will start without glow plugs when temps are high.
But using glow plugs sure does save the starter, which is rather expensive.
Diesel does not autoignite till close to 500 degrees.
Even at 100 degrees ambient air temp, one compression stroke to raise cylinder temps from 100 to 500 degrees is asking a lot from the starter.
There is a lot of metal that is soaking up the heat from compression.
If you still had air in the injection lines, it will cause the injection pressure to drop more slowly and inject more fuel than it would if the injection lines only contained fuel.
I would try running it again, if the fuel smell continues, then you have an injector that is leaking, possibly more than one.
With the cost of fuel these days, and the cost of injectors, a new set may pay for themselves rather fast if you drive your truck very much.
Old Aug 11, 2008 | 04:44 PM
beerman2therescue
Thanks dave I was thinking of buying new injectors because I havent a clue how old any of them are!
